b16 to b17
Old Jan 4, 2007 | 07:50 PM
cornflake's Avatar
813's Finest
Default b16 to b17
my friend is swapping out a b16 from his crx and puttin in a b17 engine. hes keeping all the wiring the same, question is the coolant sensor on the back of the block is differnt sizes, what should he use/do?
Old Jan 4, 2007 | 08:04 PM
Eluzzionz's Avatar
use the one that fits?....also why go throw the hassel of swappin a b16 for 17?...power difference is very minimal 6xtra lbs tq doesnt seem worth that hassel..however if ur friend wants some real power increase...ill be selling my b18a high comp ls bottom end..thats vtec ready...and that will def increase his hp and tq..it has 6000miles on it..and right now has a b16a head on it...if interested lmk...he can come take a look at it running
Old Jan 4, 2007 | 08:11 PM
cornflake's Avatar
813's Finest
b16 is blown btw, anyone else
Old Jan 4, 2007 | 09:17 PM
Eluzzionz's Avatar
o ok
Old Jan 4, 2007 | 11:01 PM
HondaHouse's Avatar
IS AT THE DEALERSHIP NOW
the b16 is an obd0 block if the fan switch is on back of block......b17 motor is an obd1...fan switch is on thermostat housing......extend your fan switch wires and use according plug....make sure you solder and heatshrink your connections......done it many times, no problems
Mike @ 239-851-3234...anything pertaining to HONDAS
Originally Posted by Jordan T
sounds like you have a problem, your car is a mitsubishi, try replacing it.
Old Jan 6, 2007 | 01:56 PM
integra's Avatar
90% grind 10% sleep
is this the b16 crx that was baught from me? if so pm me a number i would like to hear about it,or help out in anyway
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Jan 10, 2007 | 08:53 AM
integra's Avatar
90% grind 10% sleep
bump for a answer
Old Jan 11, 2007 | 08:08 AM
juiced2ndgenteg's Avatar
just cut the plug off the fan switch wires. connect them together. The fan will come on any time you turn your can to on. I like haveing the car setup that way. Then you don't question is the fan is going to turn on when you need it to. Sometimes those sensors go bad and you'll overheat your engine.
