help removing oil pan!!!
Old Dec 27, 2006 | 05:16 AM
icebox's Avatar
Default help removing oil pan!!!
I have removed all 18 bolts securing the oil and tried to bang the oil pan with a rubber hammer. But this thing would not come loose. Is it ok if I pry between the block and the oil pan? Will this damage anything? Or is there another way to take this off?
Old Dec 27, 2006 | 06:33 AM
Gixxer's Avatar
Hide your daughters
I had to use a flat head to pry it off carefully, just make sure you use a brand new oil pan gasket afterwards.
Old Dec 27, 2006 | 06:38 AM
skunk2racing97's Avatar
UF Mech/Aero Eng
+1
very carefully.
if you tear up the mating surface you will have never ending leaks.
Old Dec 27, 2006 | 08:50 AM
Pyroproblem's Avatar
Porsche Tech/Honda Tech
Sure you got ALL the bolts AND nuts including the ones BEHIND the flywheel plate?
Now residing in Atlanta.....
Old Dec 27, 2006 | 03:14 PM
icebox's Avatar
yeah all 18 bolts including the ones behind the flywheel.
anybody want some extra cash and remove this for me?
Old Dec 27, 2006 | 03:46 PM
FC_V8's Avatar
If you got all the bolts off then just pry it off. its not that hard.
Old Dec 27, 2006 | 04:11 PM
huntarrr's Avatar
If its not coming off fairly easy you've missed one or two bolts. Try hitting it with a rubber malet before prying it with a flathead. Good luck.
Old Dec 27, 2006 | 08:39 PM
If this is a B series, there are 19 bolts/nuts holding the pan on...
Old Dec 28, 2006 | 06:28 AM
icebox's Avatar
after almost 2 hours of cutting away the honda bond and carefully prying it, the pan is off. but i only see a thin layer of honda bond between the pan and the block. there is no gasket at all. do i have to get a gasket for it if i'm putting it back on? btw this is for f23 block
