cams and boost
Old Dec 26, 2006 | 02:47 PM
clean teg's Avatar
Default cams and boost
can i run 404s with boost some people say yes and some say no i need someone to be more procise on this please
Old Dec 26, 2006 | 03:00 PM
Pyroproblem's Avatar
Porsche Tech/Honda Tech
You can run whatever cams you like and boost.
Its just at stock cam timing, there may be too much valve overlap and you may get some of your intake charge go right out the exhaust and result in low power.
Solution? Adjustable cam gears. Advance the exhaust or retard the intake so you have less overlap and keep more charge in the cylinder...
Now residing in Atlanta.....
Old Dec 26, 2006 | 03:39 PM
Alpha's Avatar
I ran Crower 62404's in my last setup with my GT3076RLE. A couple video's below. I cant remember if I was at 11lbs or 14lbs when I ran the GT30R GST
* Driving around partial throttle and coming to stops
* Dario's GT30R vs me at 11lbs or 14lbs with three people in the EG
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Dec 26, 2006 | 05:00 PM
clean teg's Avatar
Thanks Alpha ,pyroproblem
Old Dec 26, 2006 | 05:04 PM
clean teg's Avatar
alpha that bitch sounds nasty !!!! thanks again for the info
Old Dec 26, 2006 | 05:15 PM
Alpha's Avatar
Yeah. It sounded nasty. Just got annoying with the open 3" downpipe. Couldnt hear the engine or anything else for that matter
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Dec 26, 2006 | 05:22 PM
Alpha's Avatar
Be sure to post up your results. Let me know if you need anything else
* IP E-Mail
* IP Face Book
* IP Web-Site
clean teg's Avatar
the need for speed lol
Old Dec 26, 2006 | 05:25 PM
clean teg's Avatar
yes sir most likey john vega will be tuning it ill keep you posted
Old Dec 26, 2006 | 05:37 PM
Alpha's Avatar
He will do good. Get some cam gears on those cams. Built bottom end?
* IP E-Mail
* IP Face Book
* IP Web-Site
