accord wireing problem maybe ???
Old Dec 22, 2006 | 07:40 PM
Ares's Avatar
Default accord wireing problem maybe ???
ok my daily driver is like fucked up O_o. well at anyrate i think there is something wrong with the wireing.the right tail light stays on all the time weather the key is on or off. and the turn signals dont work in the back nor do the brake lights. but the turn sigs work in the front so do the lights. any ideas ???
btw its an 88 accord.
there are those of us who choose to fight and those of us who choose to stand on the fence and watch not wanting to get involved. but we all search for a small measure of inner peace but few of us ever find it
Old Dec 22, 2006 | 08:44 PM
TSX24L's Avatar
iam not sure on 88's! but i know like around 90ish accords they have left and right brake light sensors. Does the high mount or third brake light come on also? Continously? And you said that the right side stays on all the time? Blinkers don't work etc.. But the brake lights stay on. I would do a continuity check between the brake sensor and high mount brake light, and both inner and outher brake light on the right side. I would say that if you don't get a complete circut you probably have a short in the brake light sensor. Unless you think you have a break in wires like accessories etc.. that you might have or seen installed? Or you could maybe just swap left to right brake sensors and see if the left side does what the right side did? The brake sensor is located on the body panel were the tail lenses go.
It would be best for you to get a etm so you can see where iam talking about. Because there are several connectors for you to check. Someone else might have a better way though for check this.
I couldn't imagine this being a brake switch because only your right side brake lights stay on.
Old Dec 23, 2006 | 07:17 AM
Ares's Avatar
well as far as the repair manual goes theres no brake light sensors the guy at the auto parts store say somthing about a switch under the pedals that might be bad. or stuck on thas why the one light works and it has burned out all the other bulbs. maybe thas it anyway any other ideas ??
Old Dec 23, 2006 | 09:49 AM
Check bulbs first, then fuses, then wiring.-Bob
Old Dec 24, 2006 | 08:36 AM
Ares's Avatar
actuly i found the problem lol first off all of the bulbs in the rear were missing lol and also there was a problem with the brake light swicth by a gromet was missing by the pedal i replaced the groumet and now everything works also i replaced the bulbs thanks for all the help
