I got a nice suprise while doing my brakes:mad:
Old Dec 19, 2006 | 08:04 AM
EGKID's Avatar
Default I got a nice suprise while doing my brakes:mad:
First of all the car is an HF CRX with an LS swap, the guy that had the car before me did the swap and used the SI hub on the driver side and I have no idea what the hell he did on the other side
These are the brake pads which hung over the rotor about a 1/4 inch
Another view
I'm hoping all I have to do is replace this piece which the brakes fit in, and this brings me to my question whats the name of this peice?
Also the caliper doesnt slide easily up and down after you remove the bottom bolt I have to use all my wieght to move it
Ricky
Old Dec 19, 2006 | 09:50 AM
Presidential_Detail's Avatar
aka The Twanksta!
That sucks. maybe he put the bigger brakes on but not that bigger rotor?
As for the caliper not sliding easily, it wont unless you loosen the top side a lil also..GOOD LUCK!
Visit Our Site - Presidential Automotive Detailing
Authorized CQuartz FINEST Installer
Old Dec 19, 2006 | 09:59 AM
EGKID's Avatar
There is no nut on the top, on my old hatch and the driverside it just slides right off, I'm just gonna replace that bracket and caliper.
I dont know if thats an LS hub or if its just the bracket and calipper, does anyone know if it's interchangeable with CRX SI parts?
Ricky
Old Dec 19, 2006 | 10:01 AM
EGKID's Avatar
Also notice how the back brake pad isn't worn out at all so the caliper must have been frozen in place or something
Ricky
Old Dec 19, 2006 | 06:59 PM
J240sx's Avatar
thats the actual bracket to the caliper looks like the pads and calipers are too large for the rotors. that's why one pad has a lip. Also if the caliper is locked on Honda's you can usually just grease the slidings and walaa. Unless you wanna replace the calipers which shouldn't be to bad.
Old Dec 19, 2006 | 07:00 PM
J240sx's Avatar
yeah there is a top bolt...
Old Dec 19, 2006 | 07:06 PM
EGKID's Avatar
Im just replacing the bracket and caliper. $55 for everything brand new
Ricky
Old Dec 19, 2006 | 07:17 PM
rangcrx's Avatar
engine building &best
yup thos are hf rotors you can tell thay dont come close to the braket thay should be with in like mm of it thats about 1/4" i would find a a another rotor and compair
i love AUTOZONE
Old Dec 20, 2006 | 03:40 PM
EGKID's Avatar
Im pretty sure it's an LS caliper I dont want to get the rotor for it becuase then I'll have 2 different size rotors, I already ordered my parts and they sure be here tomorrow or friday, I'll keep you guys updated.
Ricky
Old Dec 23, 2006 | 09:02 AM
If he put on bigger calipers, and did not change the rotors,
I would take the caliper to a dealer, and see what rotors goes with that caliper number.................and buy the rotors to match it.
To clarify: rotors are always replaced in pairs if they are
not the same-side to side.-Bob
