Brian Crower Stroker Kits-Does this make sense?
Old Dec 19, 2006 | 11:48 AM
wb_map3's Avatar
you can achieve the 9000 range with that kit but its so famn expensive if you just bore out a b20 it will be the same for less money
im grown but yea bitch i got batman bedsheets
Old Dec 19, 2006 | 11:49 AM
Eluzzionz's Avatar
i think i said that too?
Old Dec 19, 2006 | 12:49 PM
KJ's Avatar
KJ
bored at work
This kit is a bore increase and a stroke increase. If you read the description you will see them mention "aluminum buttons/rail supports", this means the oil control rings sit at the same level as the wrist pin. This leads me to believe the ring package as a whole is very short and thus not going to be very good for turbo. All the motors I've ever seen with oil rings in the wrist pin bore have had alot of oil control problems also. If you are planning on going turbo just have the motor sleeved and bored to 84mm and leave the 89mm stock stroke. If you really want to stroke the motor also look for a 92mm crank and pistons with a standard ring package and adjust rod length accordingly.
Don't get all hung up on rpm range, with the proper clearances you can take a 95mm cranked motor past 8k rpms as long as you understand the effect it has on bearing life.
Old Dec 19, 2006 | 02:45 PM
Alpha's Avatar
Originally Posted by clean teg
NOT HAPPENING
I can show you more than a couple datalogs of 9000RPM pulls from 9lbs to 18lbs of boost with my LS Plenty of people (TheRedDragon, Brothers, Julian, Dario, Jap, etc) have seen me do it I'm not recommending everyone with an LS do it
Originally Posted by mtber
Perhapse he was confused with his bseries vtec kit ?
I will put my money he was confused with VTACK application
Couldnt have said it better
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Dec 19, 2006 | 09:16 PM
Cold_Beer's Avatar
Rockin' 4 more Cylinders
+1 to teh Ls at +9k rpms, ive seen it and done it several times on some of my old motors
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old Dec 19, 2006 | 09:20 PM
GsEclipse02's Avatar
ill vouch and you were stilling pulling vtec cars that were in your power levels
