Car won't start after driving it
Old Dec 15, 2006 | 05:35 AM
buylow's Avatar
Default Car won't start after driving it
Ok.. here how it went down:
Started car in morning and started my daily commute. Drove for 10 minutes. In rush hour, by car was sitting in traffic. It stalls and won't start up again. I can crank the motor, but it won't start.
There is power to the car. Oil is fine. The fuel system seems ok since I can smell the gas getting to the motor(but initially I thought it might have been the fuel pump). The spark plugs/wires were replace recently. Filled the gas yesterday and drove only 30 miles on the tank. Can it still be the lack of spark or can it be bad gas?
Any suggestions?
Ride : 94 honda civc hatch
Old Dec 15, 2006 | 05:54 AM
Derka's Avatar
TR Balla Donor Supreme
check to see if it has spark, it sounds like the coil went bad
1998 crv daily beater
Old Dec 15, 2006 | 05:58 AM
Brownsound's Avatar
Dude.. thats awesome.
Can you start it when its cold? i.e, could it be the main relay?
Old Dec 15, 2006 | 06:13 AM
buylow's Avatar
Yes.. I drive it every morning. It my daily driver with over 228K miles. It always start in the cold with no problem. The motor is running strong. I drive it about 80 miles a day and never had a problem with the car.
If I can't figure it out, I going to need someone that know more about car than me to look at it. Where is the near import shop in Pasco near I-75/Rt56.
Old Dec 15, 2006 | 07:28 AM
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
had this same problem not to long ago.car started and then shut off and wouldn't start again.its most likely your dizzy.I replaced my coil and it still wouldn't start.
-Winston Churchill
Old Dec 15, 2006 | 09:52 AM
juiced2ndgenteg's Avatar
+1000000000000000000000000000000
Old Dec 15, 2006 | 09:54 AM
Pyroproblem's Avatar
Porsche Tech/Honda Tech
Could also be your igniter. Its inside your distributor also...
Now residing in Atlanta.....
Old Dec 15, 2006 | 09:55 AM
Rican Pride 06's Avatar
Coil.
_JJ
Old Dec 15, 2006 | 04:20 PM
hondachris1994's Avatar
hatchback1994
replace distributor, I could almost gaurantee thats the problem, especially if u can hear the fuel pump priming
Old Dec 15, 2006 | 04:35 PM
Eluzzionz's Avatar
COIL +100000000 thats what happend to me..embarrassing...just get a volt meter and check it..or find a friend..swap out and see if it starts..
