92 civic climate control wont light up
Old Dec 13, 2006 | 11:34 PM
MAYMAY's Avatar
Default 92 civic climate control wont light up
the climate control , digital clock and hazard light switch will not light up (the hazard switch funtions well and climate control works, the tiny indicators in the middle of the button work and light up too just not the back ground light)..but the instrument gauges work and light up fine..is that because the blown fuse or ?and which fuse should i replace..cause i dont have a manual in hand.thanks
Old Dec 14, 2006 | 07:27 PM
Obviousreasons's Avatar
Welcome to Candy Mountain
I would check all your fuses with a test light. And if they are fine, might be the bulbs. That car IS 14 years old. LOL.
Need your Honda/Acura tuned? Ecu Chipped?
Http://www.Phearable.net
Need some Stereo/Security/Video Work Done? Almost Anything 12 Volt I can do. 12 Years Experience. Send a PM For Inquiries.....
Old Dec 15, 2006 | 09:47 AM
DD.'s Avatar
DD.
Administrator
+1...
Do you have HIDs? sound system? anything that could drain power?
