ball joint question
i replaced the axles on my 96 hatch. when i separated the ball joint i tore the boot and all the lube leaked out. the question is can i just replace the joint or do i need the entire spindle? any help is greatly appreciated!
THANKS!
THANKS!
I AM THE MADMAN
I AM THE MADMAN
well the stud spins when i try to put the castle nut on. so i figure that i need to replace the thing but do i need to get the whole spindle or just the joint? and can i put the joint in by myself or do i have to get a shop to do it?
I AM THE MADMAN
I AM THE MADMAN
If the joint spins when the castle nut goes on, I just push the joint in harder until it's held enough to get the castle nut back on.........no big deal. If the joint is loose enough to turn/rotate it by hand, replace the joint.
You can get some replacement ball joint boots at Pep Boys.
They come in bubble packs with a red background that says "Help".
Next time, contact me. I have the tool that pops joints out of the control arm, (or tie rod ends) without destroying the rubber boot.
I also pop them loose when I do a free ball joint test for people.
I show them the difference between a good joint and a bad one,
and they can SEE if they need replacing or not......I DON'T do the
"shake 'em and sell 'em" trick.
Only when the b-joint is welded in (usually to the top a-arm, if at all)
only when welded, do you need to replace the arm. If it's the spindle end,
most times it is pressed in or has a snap ring. If you need a hydraulic press, get back with me. I have one.-Bob
deff for me like a 5 lb sledge + angry person = ball joint out
-Darren
03 Cobra Vert: Whipple, Lt's, H-pipe, SRA, 325 MT Dr's, more bolt-on's - Weekend Beater
88 Mustang Coupe: Gutted - Project
-Darren 03 Cobra Vert: Whipple, Lt's, H-pipe, SRA, 325 MT Dr's, more bolt-on's - Weekend Beater
