Need Help. Just a small question.
Old Dec 8, 2006 | 12:48 PM
bravesoccer06's Avatar
Default Need Help. Just a small question.
Ok i have a 95 civic ex and was wonderin if i order the yellow fog lights, how do they mount into my bumper? and is the wiring really hard.
Old Dec 8, 2006 | 02:41 PM
a10secstreetcar's Avatar
Depends Does the bumper have a factory spot for them? If so well there is your mounting spot. About the wiring depends on were you bought them (what kit).If they are a stock kit I think you will also need the fog light switch in the car to?(not sure on that one)
Old Dec 8, 2006 | 03:19 PM
it has a spot but there is like some little like bumper moldings in the way. but on ebay it comes wid the switch.
Old Dec 13, 2006 | 04:58 PM
If you want someone to look at it, pm me. I can show you how to wire it. no charge.-Bob
Old Dec 13, 2006 | 05:24 PM
Cold_Beer's Avatar
Rockin' 4 more Cylinders
if your talking about these fogs
you cut out the spot on the bumper where they are, just cut then test fit, then the fogs bolt into factory bolt holes with 10mm's. The wiring is straight forward, most kits come with good directions.
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old Dec 13, 2006 | 05:58 PM
HondaHouse's Avatar
IS AT THE DEALERSHIP NOW
If your using the factory wiring...its all plug and play..just did it to wifes car...wiring is all there from factory on an ex..hers is a 94....subharness goes between headlight switch and foglight switch....and outside there is a little barrel plug behind the drivers headlight in the area of the washer resevoir...blue in color...other than just cutting..the outline is there from the factory on the back of the bumper...very very easy, just cut it with an air saw...and enjoy
Mike @ 239-851-3234...anything pertaining to HONDAS
Originally Posted by Jordan T
sounds like you have a problem, your car is a mitsubishi, try replacing it.
