issues
Old Dec 4, 2006 | 03:08 PM
silver97civic's Avatar
Default issues
well my friend has problems with his civic. he tries to start it but dosent want to start. starts a few seconds then it stalls. i told him to change the fuel filter and it still stalls. could this be the fuel pump? Or, is there another filter that im not aware of?
Old Dec 4, 2006 | 03:11 PM
hondachris1994's Avatar
hatchback1994
check engine light on?
Old Dec 4, 2006 | 04:19 PM
skunk2racing97's Avatar
UF Mech/Aero Eng
+1 ^^^^^
if you give it gas while you are cranking it, will it run?
does it drive if ^above^ is true?
have you done a compression test?
Old Dec 4, 2006 | 05:01 PM
he gets it started but it then stalls.
Old Dec 4, 2006 | 05:09 PM
UF Mech/Aero Eng
so you CANT drive it? even if you keep revving it?
and you DIDNT do a compression test?
im just trying to ask this stuff to help narrow down the possibilities....
could be bad headgasket/rings.
could be poorly adjusted idle.
could be malfunctioning FITV or air bubbles in the coolant.
could be malfunctioning distributor.
could be incorrect engine timing.
could be worn spark plugs.
could be any combination of anything else....
please give us some more info and we can help from there.
Old Dec 5, 2006 | 12:32 PM
hatchback1994
IS THERE A CHECK ENGINE LIGHT ON????? If we know that we can help u from there
Old Dec 5, 2006 | 12:51 PM
UF Mech/Aero Eng
lmao! +100000000
Old Dec 5, 2006 | 07:04 PM
hey guys i know you want to try to help but i am only getting a little info as well. i talked to him this am and he says that the car does not stay idling and he has tried new spark plugs and nothing. also he did say he was at a stop sign and then i shook and stalled. that is all i know at this point. i know he hasnt done a compression test either. i did mention a possible bad distribitor to him.
Old Dec 5, 2006 | 07:57 PM
UF Mech/Aero Eng
i have a similar prob in my civic. idles like crap, if it idles at all, and everytime i come to a stop it stalls.
i did a compression test and the biggest number i saw, with capfuls of oil and battery-killing-hours-of-cranking was 90.
so do the compression test, and either give us results, or tell us if there is a CEL.
i dont want to hear anything till then
