00 Civic Ex speedo problem
Old Dec 2, 2006 | 12:07 PM
F4A22's Avatar
Old School
Default 00 Civic Ex speedo problem
After i changed my longblock today the speedo stopped working.Its throwing the code for the sensor and also my cruise stopped working.Both were working perfectly fine before the swap and they were simply unplugged and plugged back in.I'm pretty sure the cruise is tied in with the speedo but i dont understand why it would simply just quit working not being fucked with.Ive erased the code once and it came back.If anything i can try one next week from a 96-98 hopefully its the same sensor.
Old Dec 2, 2006 | 12:49 PM
skunk2racing97's Avatar
UF Mech/Aero Eng
all you changed was the block? did you plug the VSS back in?
you may have a bad VSS, it happens on occasion, but not very often.
check the plug at the VSS to make sure you are getting voltage. if my memory serves me it should be 5V ish...?
Old Dec 2, 2006 | 12:51 PM
F4A22's Avatar
Old School
I got a used longblock not a tranny.All i did was unplug it and plug it back in to get more slack for the engine harness.
Old Dec 2, 2006 | 05:04 PM
Derka's Avatar
TR Balla Donor Supreme
is the speedometer working or is it just throwing a code?
1998 crv daily beater
Old Dec 2, 2006 | 07:50 PM
UF Mech/Aero Eng
well if you just unplugged it, and plugged it back in, and now it doesnt work, either:
a) the wiring changed
b) the VSS changed/got broke
c) you changed something else you dont know about
Old Dec 2, 2006 | 10:13 PM
Presidential_Detail's Avatar
aka The Twanksta!
check all your harness grounds(your main harness ground on the thermostat), usually is the problem that ive seen...
Visit Our Site - Presidential Automotive Detailing
Authorized CQuartz FINEST Installer
Old Dec 3, 2006 | 05:00 AM
F4A22's Avatar
Old School
Yea its getting 12v,5v, and nothing which i'm guessing is signal.I'm getting one tommorow from honda.The grounds also checked out good.
Old Dec 3, 2006 | 01:19 PM
F4A22's Avatar
Old School
Put a used one on today from a 99 lx.Still the same problem.Part number was different but the sensor was identical.I'll call honda in the morning and see if thier different sensors.
Old Dec 3, 2006 | 01:49 PM
UF Mech/Aero Eng
it doesnt matter... you should still get some reading...
the VSS is just a gear that spins off another gear thats mounted on the differential. if the VSSs are working, which i would assume at least one is, then you should get some reading at the speedo, unless there is a problem with either the wiring or the cluster itself.
i was running a D16 trans (with a D16 VSS) for a coupla months while i had an Si cluster (that reads off a B16) and it all worked fine, just off by a few MPH cuz of the final drive difference....
Old Dec 3, 2006 | 02:02 PM
F4A22's Avatar
Old School
I reset the code and it hasnt come back.I'll check the wiring for a break tommorow.
