Single cam+boost+spray?
Old Nov 26, 2006 | 11:28 AM
Derka's Avatar
TR Balla Donor Supreme
Default Single cam+boost+spray?
Well i think i want to spray the single cam. I run an 8.9 lb spring in it now. I think i want to do like a 35 shot. Will i need to do a wet kit or can i just do a simple dry setup?
1998 crv daily beater
Old Nov 26, 2006 | 11:30 AM
clean teg's Avatar
make it a 100 lol
Old Nov 26, 2006 | 11:35 AM
Derka's Avatar
Originally Posted by clean teg
make it a 100 lol
Sounds good to me.
Old Nov 26, 2006 | 12:03 PM
95gainfla's Avatar
smokes weed...everyday.
get a dry kit, and run 93 octane. thats all you need.
I <3 RooR!!!!!!
Old Nov 26, 2006 | 01:21 PM
Alpha's Avatar
Why not turn up the boost? Unless you're running a GT22 or something stupid small 9lbs is nothing
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Nov 26, 2006 | 02:22 PM
JDMjunkie's Avatar
No in this case WET would be you choice as it will act like a coolant when you spray. it helps cool your engine down when your running boost id boost it up a little more and do maybe a 25,35 shot should be nice but i hope your bottom end is set nice is it?
TampaRacing's DEAD!!
Old Nov 26, 2006 | 03:42 PM
Derka's Avatar
I think you might be mistaken. What makes nitrous work is the cooling effect it has on the engine internally. The difference between wet and dry is that dry is just straight no2 where a wet setup is n02 mixed with fuel also being added
Old Nov 26, 2006 | 03:44 PM
Derka's Avatar
yea your probly right. Its only 9lbs on a t3 super 60. I might go to like 13 or so with a tune
Old Dec 1, 2006 | 04:42 AM
Si_Vtec's Avatar
if u have the z6 motor or the d16y8 then u can throw a 100 shot on that bitch. just dont go hitten the spray every weekend, cuz u will blow that motor. as of fuel go 550cc injectors and run 110 octane on the nite ur feelin that spray creep up on u. lmk how it goes man. gl
Old Dec 2, 2006 | 09:39 AM
nefesto's Avatar
Your Mother's Best Friend
???? I don't follow. explain
