K series block question....
Old Nov 25, 2006 | 07:43 PM
fokissed's Avatar
Default K series block question....
Ok i am building a k-series EK9. I need to know which type of block is better for running high boost (i am going to do the internals and all.) Which block should i use on a k20a2 type s head:
K24 block
K20a2 block
and
with having high boost which tranny would be best
5 spd
6 spd
or
6 spd LSD
Old Nov 25, 2006 | 08:07 PM
ResurrectedLS's Avatar
On the block
def 6 speed and it also depends how much boost u planing to run on the beast
Old Nov 26, 2006 | 03:52 AM
fokissed's Avatar
anywheres between 15-30 not sure.
fokissed's Avatar
thought so with the 6 spd but should i convert it to LSD
Old Nov 26, 2006 | 10:35 AM
JR.'s Avatar
JR.
^ find out what LSD means and u should anwser ur own ?
98 talon awd automagic
Old Nov 26, 2006 | 10:58 AM
na200whp's Avatar
Powered by BOOST
id say 5 speed if your going to make alot of power or you will be shifting into 6th gear.
as far as block choices I say k24
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
Old Nov 26, 2006 | 03:42 PM
fokissed's Avatar
i know what LSD means limited slip. most likely i will burn out throught most of the gears with LSD right? so would it be a good idea to have LSD with that type of power? it seems like a good idea not to have LSD but im wondering how is it with LSD.
Old Nov 26, 2006 | 06:02 PM
freakasis's Avatar
lsd will make both wheels spin rather than just one...i cant think of a situation where you wouldnt want to have it.....so if you have the money get it....and go with the k24 bottom end.....the liters count for somthing.
Old Nov 28, 2006 | 08:39 PM
T4eg's Avatar
K24 block
K20a2 block
and
5 spd
6 spd
or
6 spd LSD
either block will work, but id use 5speed trans
