map sensor
Old Nov 26, 2006 | 09:33 AM
hondachris1994's Avatar
hatchback1994
here's a map sensor on a b16 its #13 on here and its on top of your throttlebody, not intake(my bad) Honda Automotive Parts
Old Nov 26, 2006 | 09:36 AM
hatchback1994
or #22 on here Honda Automotive Parts
Old Nov 26, 2006 | 09:38 AM
hatchback1994
those are both b16 engine's, the first 1 is from a 99 civic SI(B16a2) and the other 1 is from a 94 delsovtec(b16a3), but all B16's are the same
Old Nov 26, 2006 | 10:02 AM
ResurrectedLS's Avatar
On the block
nah bro none of does r like mmine i got like the first b16a eva made i thnk my motor head shows a 89 b16a1
Old Nov 26, 2006 | 11:14 AM
hatchback1994
but the map sensors are all in the same location, and none of them have hoses goin to them, all B16 mani's and TB's are pretty much the same, check your wires on your map sensor thats prolly your problem
Old Nov 27, 2006 | 07:04 AM
freakasis's Avatar
since this is obd-0 im sure it still have the stock civic map...which is on the firewall and had a hose going to the manifold.....what you should do is get the right throttle body with the right map and just run the wires from the one on yer firewall to the new one on the t/b the way it should be....any Qs?
