driver-side B-series mount?
Old Nov 25, 2006 | 03:30 AM
hondachris1994's Avatar
hatchback1994
Default driver-side B-series mount?
What yr and car do I order the upper driverside mount..my car eg(civic cx) with b16a2, and my mount isnt broken but the rubber is startin to fall apart, would I b better off gettin inserts or a new mount, what do u guys think?
Old Nov 25, 2006 | 05:20 AM
00siboy's Avatar
Bone Stock
try hasport.com IIRC.. they make the hybrid mounts
-Darren
03 Cobra Vert: Whipple, Lt's, H-pipe, SRA, 325 MT Dr's, more bolt-on's - Weekend Beater
88 Mustang Coupe: Gutted - Project
Old Nov 25, 2006 | 06:28 AM
hatchback1994
I just need the driverside mount hasport only sells them in a package, I already got the tranny and rear hasport mounts
Old Nov 25, 2006 | 06:34 AM
warpd's Avatar
It would help if you would specify what car it is going into. But I am going to assume you are using it for an EG chasis. If thats the case you will need a 94+ DC integra driver side mount. you can buy them at autozone, or dealer. I do like the motor mount inserts more though. But they do cause a little more car vibration at idle.
(813) 523-0168 Sid
(813) 476-5383 Justin
Old Nov 25, 2006 | 07:35 AM
hatchback1994
Originally Posted by warpd
you will need a 94+ DC integra driver side mount. .
do Im order it from a LS or GSR, or are they both the same?
