Dyno Update k24/k20 turbo
I was lucky enough to get some time w/ Jason (60-1EK)on the dyno today. The map I was useing was a base map for a similar setup and was modified to my car. Jason tuned some A/F and some timing but cam angles were untouched. the car was tuned at 7-8 psi , 15-16psi and one pull were boost cut kicked in at 18psi . These were pump gas pulls and were kept conservative due to stock sleeves. The laptop would not stay connected above 6500 rpm so boost levels are not completely accurate ( i dont have a boost gauge) .
I want to say a Big Thanks to Jason for giving me his time and for the tuning help!
first graph is 15- 16 psi
second is when the car hit boost cut at 18psi
last is an overlay of 7-8 psi and 18 psi
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
K series on crack
S D M
Looks good Steve!
Congrats man nice #, and get a boost Gauge Lol
-Induction Performance
ALPHA Tuned.
-ROQUE MACHINE SHOP
For ALL your fabrication needs.
-ROQUE MACHINE SHOP
very nice
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
looks good steve, I got the k24a1 block from work yesterday, Hopefully I'll be joining you here soon!!!!
http://www.inductionperformance.com/
R.I.P
Kevin "Slo_Si" Gonzalez
6/21/86-9/13/06
Pablo Garcia
9/28/85-9/05/07
You will be missed and remembered forever!!!!
R.I.P
6/21/86-9/13/06
Pablo Garcia
9/28/85-9/05/07
hey Steve, If you dont mind me asking, What size injectors are running?
R.I.P
6/21/86-9/13/06
Pablo Garcia
9/28/85-9/05/07
R.I.P
6/21/86-9/13/06
Pablo Garcia
9/28/85-9/05/07
the low/mid range power of this motor is unreal. the car hits vtec at 3750 and is at full boost (on low boost) with in a few hundred rpm later.
K series on crack
S D M
K series on crack
S D M
