EG driverside mount?
Old Nov 20, 2006 | 02:26 PM
hondachris1994's Avatar
hatchback1994
Default EG driverside mount?
What tool(s) do I need to change this mount and how hard is it? Its not broke but the rubber inside is starting to come out..BTW eg with B-Series
Old Nov 21, 2006 | 01:31 PM
hatchback1994
Do I need to place a jack to rest the engine on or will the motor stay in position without using a jack?
Old Nov 22, 2006 | 04:11 PM
CFP_IVAN's Avatar
CFP was...
use a jack with a 2x4 piece of wood in betwen. raise until you see engine lift a half an inch, then you can remove the mount is a 17 or a 14 or both.
Old Nov 22, 2006 | 05:13 PM
hatchback1994
Where do I put it to jack it up? I was told use the 2x4 and jack and raise it from the oilpan, but that doesnt seem rt and im not tryin to bend the oilpan..ant help is appreciated ...thanx
Old Nov 22, 2006 | 06:24 PM
CFP_IVAN's Avatar
CFP was...
OIL PAN WILL BE FINE. DONE IT MORE THAN A HUNDRED TIMES.
