b16 tps sensor
Old Nov 18, 2006 | 03:14 PM
ResurrectedLS's Avatar
On the block
Default b16 tps sensor
i need a tps sensor for a 89 bl6a1 rex
need the part asap got cash
Old Nov 18, 2006 | 03:34 PM
skunk2racing97's Avatar
UF Mech/Aero Eng
did you post in the 'for sale' forum too?
you might get more responses there.
and i think all the honda TPS's are the same... at least 88-01 anyway...
Old Nov 18, 2006 | 05:42 PM
EGKID's Avatar
your better off getting a whole throttle body
Ricky
Old Nov 18, 2006 | 06:19 PM
On the block
oo thankz egkid but i got a single cam vtec one would it work on the b-series which is a 91tps sensor
Old Nov 19, 2006 | 08:50 AM
UF Mech/Aero Eng
yes, all the H-, B-, and D- series TB's are interchangeable, provided you get the IACV setup for you car. (some of the D16 used a TB mounted IACV). but keep in mind the smaller TBs will limit airflow.
Old Nov 19, 2006 | 09:32 AM
TSX24L's Avatar
You can use a chizele of a flat tip and break loose the riviets on the tps center and make self adjusting screws if you can't find a tb for your. And car for adjustment use a dvom or listen using the motor rpms. I had atleast 10 of these laying under my work bench at work. I still might have one. I will let you know monday if you haven't found one.
More then likely from a y8 cause thats mainly what iam dealing with all the time.
Old Nov 19, 2006 | 03:48 PM
UF Mech/Aero Eng
you can also use a dremel, cut slits in the rivets, and turn them into slotted screws.
Old Nov 19, 2006 | 04:00 PM
On the block
