any feedback on mrgasket fuel rail
Old Nov 15, 2006 | 05:14 PM
BABILLARACING's Avatar
Default any feedback on mrgasket fuel rail
I just wonder if they are any good? Thanks for the feedback in advance....OmR
Old Nov 16, 2006 | 03:28 AM
KJ's Avatar
KJ
bored at work
I had an early production piece in my hand about a year ago and the hole for the fuel pressure regulator was not drilled out completely. Assuming they fixed that then they should be a good rail, comparable with the others out there.
Old Nov 16, 2006 | 02:13 PM
TheRedDragon's Avatar
i have had aem rail it sucked had metal flakes in it brand new... golden eagle injectors didnt fit like aem's ..... got a edlebrock yes a domestic piece for im prts and fuck its the best rail ive ever had or worked with
ALPHA TUNED
Tuning, Builds, Assembly, Turbo Installs, Repairs and More
inductionperformance.com
Old Nov 16, 2006 | 11:14 PM
InsaneCivicCoupe's Avatar
Retired Ricer...
i run the mr. gasket rail on my car and it works great, and looks good too... as KJ stated, the hole for the FPR doesnt go all the way through, but there is a reason for that... Thats so people can run an external regulator, like i did... there is also another hole on the rail that is tapped, but doesnt go all the way through, and that is to mount a fuel pressure gauge... basically what im saying is there is a LOT of flexibility with it... You can use AN fittings to run whatever size lines you want, or run the supplied fittings for the stock fuel lines, and you can chose between stock, or rail mounted pressure regulator, or whatever you want... Definitely a great piece, especially for the price
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Nov 17, 2006 | 03:09 AM
thanks for the feedback I guess I get one , any idea how much hp or fuel flow can support? Thanks again......Omar
Old Nov 17, 2006 | 09:18 AM
Retired Ricer...
more that any single set of injectors can flow
Old Nov 19, 2006 | 02:22 PM
thanks I guess I will order one...............
