need help with LS rods
Old Nov 15, 2006 | 04:57 PM
stockCRXsi's Avatar
Default need help with LS rods
I just got some LS rods. some say
PR4 16
and some say
PR4 4.
does anyone know if there is a difference between them?
what does the code mean? does it mean a diferent year?
Also...
Are rod caps interchangeable between rods??
how about from a diffrent motor but with a matching number??
(the numbers are written half on the rod and half on the cap)
thanks for you help!!
Old Nov 15, 2006 | 07:49 PM
Pyroproblem's Avatar
Porsche Tech/Honda Tech
PR4 is LS
the numbers after them, I dont know. I think maybe weight groups or something related to manufacturing sequence.
I DO KNOW that the same engine can have very different numbers in them. Every stock LS Ive seen all have different #'s.
Rod caps SHOULD NOT be interchanged. If you absolutely must mismatch caps, you should get them resized at the machine shop to make sure the large end is perfectly round...(Keep the caps with their rods)
Now residing in Atlanta.....
Old Nov 16, 2006 | 10:02 AM
stockCRXsi's Avatar
my friend spun a bearing and he doesnt want to recondition the rods. can he use the 3 good ones from that motor + 1 good one from another motor???
Old Nov 16, 2006 | 11:50 AM
96ek's Avatar
yes.
Old Nov 16, 2006 | 12:53 PM
stockCRXsi's Avatar
thanks
Old Nov 16, 2006 | 01:18 PM
stockCRXsi's Avatar
are all 4 rods from one motor the same exact size?
Old Nov 16, 2006 | 04:30 PM
Neesan's Avatar
EL RIPPO
With the spun bearing, does the crank itself have to be machined?
Old Nov 16, 2006 | 04:33 PM
stockCRXsi's Avatar
yes, but honda cranks are garbage after they are machined, no one recomends using them after the spin a bearing, not even if only 10,000 of an inch in machined off.
