help!!! on my crx
well i come to find out that my driver side wheel is slanted in ,and i took the wheel out to see whats was the problem and evrything looks good and tight then i go to shake the rotor and it shakes like is loose really bad so im thinking is my hub bearing aim i right?? or is it something else i speed up to like 40 and after 40 my steering wheels turns left really bad and fast so im thinking is the hub bearing.. let me know what you guys think thanks
maybe your car is way out of alignment.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
is it just the rotor that shakes or the whole spindle? if you dont have the rotors attached with the two screws then it will be able to move around when the rims are not mounted.
if the whole hub shakes then it could be your ball joints or tierods.
has the car ever been wrecked?
if not any of the above check your alignment.
i never use those screws on my rotors.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
