b16 motor mount
Old Nov 9, 2006 | 05:32 AM
gio87's Avatar
Default b16 motor mount
i have a 91 crx si but my stock b16 tranny motor mount does not align at all with the car bracket did anyone had this problem before and might have a solution..........
Old Nov 9, 2006 | 06:11 AM
Star's Avatar
if its the tranny side,you will have to drill it out and reweld a 90-93 integra bracket in its place.its kinda pain in the ass but you have to do it with the motor in the car.PM me with a number and will give you more details,we have done these a bunch of times.........
Old Nov 9, 2006 | 08:19 AM
gio87's Avatar
the number is 863-205-6862 could reach me for sure before 4:00 p.m.
Old Nov 9, 2006 | 10:36 AM
SmokinS13SR20's Avatar
That ginger...
...or you could buy swap mounts, instead of the possibility of having incorrect engine alignment where the motor will be slanted therefore so will the trany and your axles wil not line up correctly. Yes, it will work, but you have a greater chance of popping axles.
Old Nov 9, 2006 | 04:46 PM
unique intensions's Avatar
Yeah, if the motor doesn't line up right you will be haveing alot of problems with aligning everything really. Like smokins13r20 said your axles will be poping left and right. Just make sure to get aftermarket mounts and see where you could go from there. You could order them from any where, Hasport would be a place to go and there is many more other place and companys that sell mount kits. But try figureing out if the motor will sit in properly.
Old Nov 12, 2006 | 08:34 PM
HondaHouse's Avatar
IS AT THE DEALERSHIP NOW
buy swap mounts..only hasport or arizona race machine....and linkage
Old Nov 13, 2006 | 09:04 AM
EludeR's Avatar
Their's a reason why companies like hasport sell swapmounts. Saves you the time of cutting/welding (not to mention that some of that is irreversible if you cut/weld). The hasport mounts will allow the engine to sit in their as if it was a OEM SiR.
Old Nov 13, 2006 | 06:39 PM
Star's Avatar
oem bracket $25,and what ever your welder charges.The hasport bracket pushes the engine forward anyways.So there you go.
Old Nov 13, 2006 | 07:34 PM
Cold_Beer's Avatar
Rockin' 4 more Cylinders
This isnt 1998 anymore, swap mounts are 100$ shipped off ebay. and you dont have to worry abotu your motor falling out of your car....
RIP Robert Kolp aka 00ek 4/07
_Jake D
