will b16 obd1 dizzy work on b16 obd0 engine?
Old Nov 7, 2006 | 12:58 PM
streetfusionracing's Avatar
StreetFusionRacing.net
Default will b16 obd1 dizzy work on b16 obd0 engine?
I was wondering if anyone knows if I am going to have to modify a obd1 b16 distributor to plug into a obd0 b16 harness?
Old Nov 7, 2006 | 01:18 PM
Eluzzionz's Avatar
not positive if itll plug in..but ull run into problems with it if it does..there is a reason they are obd0 and 1..
Old Nov 7, 2006 | 03:20 PM
retro's Avatar
why are you tracking me?
The OBD1 distributor can be repinned to work with the OBD0 harness...BUT is not compatible with OBD0 ECU...Must use OBD1 ecu with OBD1 distributor
