nasty oil leak. help!
Old Nov 5, 2006 | 11:33 PM
labkreationz's Avatar
Exclamation nasty oil leak. help!
i have a b16a and i have a really bad oil leak. i am dropping more then a court a wekk. i have changed the oil pan three tmes now!!! and it is still leaking.i am stumpped, and i need this car fixed. it is really gay not having a car. also if any one knows of any shops that will do it for a good price.
custom graffiti!!!
get anything you want done in graffiti.
i do rooms in house, inside, outside, custom canvas art. helmets. hats etc. ANYTHING!!!
IF YOU HAVE ANY IDEAS please contact me. via
also email for pics.
Old Nov 5, 2006 | 11:44 PM
mtber's Avatar
Check the shop directory:
https://www.tamparacing.com/forums/h...directory.html
Old Nov 6, 2006 | 04:40 AM
Old Renegade's Avatar
Cool Runnings
so you know it is coming from the oil pan gasket or is that uncertain?
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Nov 6, 2006 | 05:08 AM
skunk2racing97's Avatar
UF Mech/Aero Eng
+1
where exactly on the block is it from?
are you changing pans, or pan gaskets?
is the drain plug tightened to spec?
if its coming down from the very back, or very front of the engine, its more likely you have a bad rear main/front main seal leak than an oil pan leak.
be more specific with the prob, and we see what we can do.
Old Nov 6, 2006 | 06:49 AM
well the first time i did it i know it was the oil pan. before i was certain that it was the oil pan and that the reson it was leaking is becuase i didnt do it right. but o the third time i did it me and my brother did it totally perfect.there was so much oil coming out that it was hard to tell where it was coming from. what is spec on the drain plug?
custom graffiti!!!
Old Nov 6, 2006 | 07:20 AM
Hater's Avatar
Free base cocaine
^like ft lbs on?
Old Nov 6, 2006 | 07:30 AM
freakasis's Avatar
clean the engine and fill it up with oil than start it up and get underneith with a flashlight....if you still cant see where its comming from let someone who has experiance look for you.
Old Nov 6, 2006 | 07:53 AM
CubanYoshi's Avatar
You can't handle it
Sounds like you may be having a leak from somewhere other than the oil pan. Have you tried cleaning up the whole motor, running it around the block a few times, and then throughly inspect the motor from bottom to top to find if you have any other leaks.
THE CIVIC 2004-2009
Old Nov 6, 2006 | 07:56 AM
Cool Runnings
+1 but make sure before getting under a raised car that you stand are secure and or jack. i usually do it like this if i raise the front i chock the rear wheel with a block of wood or brick, always have on my emergency brake as habit uasually have it in gear (i know iknow the front is off the ground) when it is lowered on stands i still jack the jack up to the frame as still another precaution. sometimes can't be too safe.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
Old Nov 6, 2006 | 08:20 AM
that was my net plan clean the motor down and find out where it is coming from.
custom graffiti!!!
