eg problems
eg problems
hey TR crew...i got a problem i need help with...it may sound kinda hopeless but i cant seem to get my fuel filter off my 93 eg hacthback civic
I took the in line from the fuel rail and now i cant get the other metal line that runs to the gas tank of!....the nut is so tight on it!...i even tried using a nut wrench and it still wont come of!...and if i pull really hard wihich i did i kinda brokethe filter holder apart!...but i can fix that back!
PLEEASE HELP ME TO GET THIS NUT OUT SO I CAN CHANGE THE FUEL FILTER PLEASE!
i just switched mine out yesterday..and i took two wrenches..one on the bottom of the line..and one on the bolt..and pulled them together..and it broke loose..tryin to use one wrench or socket..(i almost broke my bracket too) but usin two made it stay in place and a lot easier..(the bottom wrench goes on the fuel filter bolts thats mounted..its like a 17mm or something)
Are you using the proper tools? You arent trying to get it off with a pair of pliers or some BS are you? Try and get a breaker bar. IE: If your using an open end wrench put a longer piece of pipe over it and then try it. Same for a ratchet.
Maybe you should eat some spinach? ... J/K
Good luck
Good luck
Need your Honda/Acura tuned? Ecu Chipped?
Http://www.Phearable.net
Need some Stereo/Security/Video Work Done? Almost Anything 12 Volt I can do. 12 Years Experience. Send a PM For Inquiries.....
+1 to usin the right tools..but im tellin u , u need two wrenchs or a wrench and socket..so u can keep the filter in place while tryin to pry the bolt loose..it was pretty quick and easy usin both vs usin one and almost rippin the bracket off the firewall
Good luck
Good luck
