pulsing idle
Old Oct 30, 2006 | 03:24 PM
primeredcb7's Avatar
I love Oral sex
Default pulsing idle
when i start my car the rpm's raise then drop then raise then drop im pretty sure it's my IAC just wondering
87 CIVIC SI HATCH--SOLD
89 ACCORD LX SEDAN--SOLD
90 ACCORD LX SEDAN--TOTALED
93 CIVIC EX SEDAN--TRADED
90 DX HATCH W/LS--TRADED
90 4-DOOR TEG LS--TRADED
93 CIVIC COUPE EX--SOLD
09 Mitsubishi Lancer--Current
93 JEEP GC 4X4--Sold
84 JEEP CJ7 4x4 w/ Chevy 1/2 ton running gear--SOLD
Old Oct 30, 2006 | 04:07 PM
Apexi96's Avatar
ur exactly correct.. thats ur problem
Old Oct 30, 2006 | 05:02 PM
TampaTraps's Avatar
get big or die trying!!
to verify this take off the intake and plug the top hole in the throttle body if it stops then it's the iacv if not plug the bottom then it's the fast idle valve. and if both plugged and still doing it you have a leak somewhere else.
that's president hussein obama to you :gordy:
Old Oct 30, 2006 | 05:31 PM
94lsteg's Avatar
BOOST IS BETTER!
it really could be any vaccum leak
Old Oct 30, 2006 | 05:38 PM
skunk2racing97's Avatar
UF Mech/Aero Eng
that, or, ive had a TPS wear bad in one spot, and as its a standard potentiometer, the voltage will jump between the closest high and low spots.
Old Oct 30, 2006 | 08:13 PM
integraman89's Avatar
lost u already???
+1.... if your car idles up then down up then down constantly, kinda like the car is breathing... its more likely to be your tps... your car wouldnt have a smooth constant idle if the IACV was bad.
Old Oct 31, 2006 | 09:44 PM
I love Oral sex
thanks all
Old Nov 1, 2006 | 03:59 PM
xxcarramr0dxx's Avatar
mine does that after i put my chip in my ecu
Old Nov 8, 2006 | 08:47 PM
Jdm-civic88's Avatar
i tryed everything i bought a new iacv and still does it i got a new throttle body and changed with new tps and map but it was used so i dont know if there sensiors where fucked to please help
-primeredcb7
Old Jan 16, 2007 | 07:52 AM
lost u already???
take it to autozone and get a free check up
