Fuses popping hlp.
Old Oct 23, 2006 | 03:48 PM
94civicb16's Avatar
Default Fuses popping hlp.
I have a civic ex. I hooked up a system today. Played fine for an hour straight. Then i turn it on later and everything shuts off. The amps, eq, headunit. I check my fuses and the radio/cigarette lighter was blown. I replaced that but right when i push it in it popped. I tried a 20 amp fuse instead of 15 and it did the same thing. Then i unhooked the wire under my hood that powers the amps. That should have illiminated it if it was a problem with the amps. Put a fuse in and it popped. Also when i am driving with lights on it makes the door ajar sound. Any suggestions. Could it be my hu?? i know its not the amps seeing as i diconnected them.
Old Oct 23, 2006 | 03:49 PM
dougy_fresh's Avatar
did u connect the dimmer?orange wire?
Old Oct 23, 2006 | 04:05 PM
94civicb16's Avatar
no i didnt. i dont ever use that
Old Oct 23, 2006 | 05:56 PM
Eluzzionz's Avatar
im guessin something is wrong with ur wirin..something touchin or groundin out..
Old Oct 23, 2006 | 06:11 PM
94civicb16's Avatar
where could it be?? what if its not behind the radio????? imma check 2marrow
Old Oct 23, 2006 | 06:54 PM
Eluzzionz's Avatar
it might not be back there..it could be something really small thats not easy to see..so make sure when u check all the wires..u check them closely..make sure the coatin around the wire isnt stripped and maybe grounding out..also just a lil info..what gauge wire are u usin for ur amps and such..and the fuse on that wire..?
Old Oct 23, 2006 | 07:08 PM
Deuche's Avatar
id you twist the wirestogether or did you use a metra Plug ? or is it all hackd up ? ill gurantee you have a ground and 12V wire touching. or teh 12V wire is grounding or pinched.
Old Oct 24, 2006 | 06:44 AM
94civicb16's Avatar
i checked and the dimmer wire was connected. I then cut it and now it works fine. why would the dimmer wire cause fuses to pop
Old Oct 24, 2006 | 11:39 AM
stockls 15.4??what's Avatar
cause your hooking it up to the wrong wire and grounding it out. just cap it and don't use it
PLAY PAINTBALL LOCALLY
http://www.blitzkriegpaintballfield.com
^^^^^^Click There^^^^^^
Modified Racing Inc. (Blown99civicSi) John Solaro
https://www.tamparacing.com/forums/h...t=john+scammer
https://www.tamparacing.com/forums/h...acing-inc.html
Old Oct 30, 2006 | 07:30 AM
no rep for help whas up?
