B20 Help
Old Oct 22, 2006 | 08:26 PM
SmokinS13SR20's Avatar
That ginger...
Is it like it hits a birck wall at 3k and just holds it without boucning or anything?
If it does, then just pull the MAIN underhood fuse for about 5 minutes or just pull it and try to turn the car over with the battery uninstalled to drain the system of power. reinstall the fuse and you should be fine.
Old Oct 23, 2006 | 01:38 AM
gsr.hatch's Avatar
no brick wall....seems as if the rev. limiter is at 3k.....checked the EACV...checked the TPS....all hoeses and ghaskets..we can't figure this one out...any help will b apreciated...rep 4 u smokins13sr20
K series}
D series} { B series}
scotty <3 roxy
...12_06_01...
William Scott Jr Preston Blake
...12_30_08... ...04_28_12...
Old Oct 23, 2006 | 03:46 AM
GSR_CRX's Avatar
fuck your srt4
ok...we managed 2 make the stock 97 b20 dizzy 2 fire the car up and run it...but would the rev. stoppin @ 3k be a result of a OBD2A dizzy on OBD0 CRX si ECU ??? crank angle wires is wired up and everything else is good...anyways someone help..thanks
_||-|| (()) ||\\|| ||)) //\\_
Originally Posted by Skippy56
Never forget.
No matter how cute she is, someone somewhere is sick of her shit.
R.I.P. Jake_D
Old Oct 23, 2006 | 01:15 PM
That ginger...
Yea, having the right ecu would help out alot guys...
Old Oct 23, 2006 | 01:54 PM
gsr.hatch's Avatar
we are now use'n obd0 EF computer-injectors-and DIZZY
K series}
scotty <3 roxy
...12_06_01...
