Clicking Noise/ 92 Ac Legend
Old Oct 20, 2006 | 11:30 AM
honduranracing01's Avatar
Exclamation Clicking Noise/ 92 Ac Legend
i recently bought a 92 legend, with a V6. its making a clicking noise that has progressively been getting worse. it does it only on acceleration and when i let off the gas at a cruising speed. it also does it softly at idle. the cars temp gauge is running normal, and it is not idling funny, so im kinda stumped. im hoping it isnt a valve, but i would like to ask some people who would know better than myself. in my twisted head im hoping its just an exhaust hanger or something, but if one of you honda guys could help, that would be greatly appreciated.
thanks in advance.
"I got my drank n' my 2-step, its on, im home get the patron and tell'em that its on!"
Learn from the past, teach the future, spank the ricers...............hard.
you know you got skills when you can drift a lawn mower. thats right, bitches, get that craftsman with 15 HP sideways.
yo, forgive my foolish talk.
Old Oct 24, 2006 | 04:13 PM
Obviousreasons's Avatar
Welcome to Candy Mountain
I Had something similar happen to me a while back. I thought it was something internal on the motor. Turns out it was the AC compressor. I just cut the belt until i got a new one. Does your AC compressor work? If it doesnt i would take the belt off and see if the noise goes away.
Need your Honda/Acura tuned? Ecu Chipped?
Http://www.Phearable.net
Need some Stereo/Security/Video Work Done? Almost Anything 12 Volt I can do. 12 Years Experience. Send a PM For Inquiries.....
Old Oct 24, 2006 | 07:03 PM
skunk2racing97's Avatar
UF Mech/Aero Eng
it doesnt sound like this, but just to check: if it happens while you turn, or sounds like its predominantly on one side, check your CV joints.
most likely, it sounds like you need to clearance your valves. if its a slight clicking at idle, and increases with RPM, and sounds like its coming from the valve cover/top end, you prob just need to clearance them. its not hard to do, just might be tough on the V6.
GL
Old Oct 24, 2006 | 08:03 PM
integraman89's Avatar
lost u already???
GL
may be a few things... like he said above... you rocker arms/valve clearence may be off a tad... so you would need to check and adjust the clearance....
the other can be, your oil squirters that lube up the rocker arms may be clogged with junk and are not lubing them properly... and finally, you need to put your ear near the motor while someone revs it up a bit to find out if it is in your top end of the motor or the bottom end... lighter/faster tapping is most likely top end... louder/slower tapping is usually bottom end.
Old Oct 24, 2006 | 08:05 PM
lost u already???
actually... on some fuel injection cars you can actually hear the injectors spitting the fuel into the cylinder... the higher you rev up the faster the injectors squirt... this is very common with older v6's and other tpyes of motors... but like i said before... just listen to it carefully. good luck
Old Oct 27, 2006 | 11:23 AM
damn yall, thanks. the a/c comp works, and so does the a/c, so ill check everything. you guys kick ass.
Old Oct 28, 2006 | 07:13 AM
Apexi96's Avatar
just what i was going to say u need a valve lash , not hard on 4s but time consuming on a v6 , it happens alot on high milage cars
Old Nov 3, 2006 | 11:02 AM
Hey, i took it to a shop, and i found out that it is most likely my "flex-plate." could someone please please explain this to my slightly stoopid ass. and if anyone knows of a respectable shop that could replace it, that would be killer.
Old Nov 3, 2006 | 11:16 AM
Apexi96's Avatar
flex plate is essentially ur flywheel(on autos) this bolts to ur torque converter
