``b18/b20 build``
I curretnly have a b series motor the block needs some reconditioning im not sure if sleeving it will fix the cracks it has so i may be looking for a b20 will the b18 head,tranny,and mounts work on that block. i know most all honda parts work on other motors and such, but this one im not sure.
Boost turns all wheels.
which b20 is it..b20b/z..head and tranny yes..not positive about the mounts..and the cost to resleeve teh block unless ur going for high hp numbers..itd be worthless to do..just find another cheap ls bottom end..also im assuming the b18 head is the ls head..non vtec..if it is vtec..itd still work with some modification or a golden eagle kit..
