straight test pipe vs high flow cat
Old Oct 13, 2006 | 05:57 PM
elwrestler03's Avatar
MrB18crx
Default straight test pipe vs high flow cat
Which on is better for my crx and will the test pipe be louder. also I have a 2.25inch exhaust would it make a diff if i get a 2.5 inch test pipe vs stock size?
wb_map3
ta b real witcha i actually 1 a spellin b as a jit n i alwayz got 100 percent on all my spellin test even got da bonus wrds rite and got an a in english 1-4 in high skool so lets leave the post ta buying and selling parts iight
Old Oct 14, 2006 | 01:52 PM
freakasis's Avatar
a good high flow cat vs a test pipe will net only a few hp somthing like 5 (on a stock motor)...the test pipe will make it a little louder because it doesnt have any the honeycombs....the bigger cat will only help you IF the insides are bigger too not just the pipes.
Old Oct 15, 2006 | 12:19 AM
flashmatrix's Avatar
Chillin in the GS3
+1 ^
"Your arms are too short to box with GOD."
Old Oct 15, 2006 | 05:49 AM
70ina30's Avatar
Broke Dem Ankles
reading in one of the import magazines about this issue. Total net gain on a honda from complete stock cat to straight pipe was only 5 hp. like ^^ said, with no insulation the pipe will be louder.
Old Oct 15, 2006 | 06:58 AM
mikroehl's Avatar
yeah, im curious about this also. I have a test pipe sitting in my garage however everyone wants to charge 100 take switch them out because of the law. I cant do it cause i can't seem to get the bolts broken loose. Is it worth the louder noise and the 100$ for 5 hp?
Old Oct 19, 2006 | 05:08 PM
freakasis's Avatar
it will cost you about $100 to get a high flow cat put on there. so with the prices being equal you might as well go the legal route.
