crx starter question
Old Oct 11, 2006 | 04:15 PM
elwrestler03's Avatar
MrB18crx
Default crx starter question
Ok so I can start my car when I hook a wire from the starter to the battery but it wont start from the ignition/key. I checked all the fuses and they are all good. What should I do next and have any of you had this problem? .My friend told me I should follow the starter wire that goes from the ignition to the starter. I found a wiring diagram but I dont understand it. If anyone could help that would be awsome.
thanks
matt
wb_map3
ta b real witcha i actually 1 a spellin b as a jit n i alwayz got 100 percent on all my spellin test even got da bonus wrds rite and got an a in english 1-4 in high skool so lets leave the post ta buying and selling parts iight
Old Oct 11, 2006 | 04:22 PM
integrex's Avatar
check your ignition
i had the same problem in my 90 ls and i just hooked up a starter button
Old Oct 11, 2006 | 04:35 PM
hondachris1994's Avatar
hatchback1994
clutch safety switch is prolly bad just jump it with a paperclip....follow the clutch pedal to the top u will see 2 wires at the top just take a paperclip and jump them together and hopeful;ly yopur problem is fixed, if u have a automatic disregaurd what I said
Old Oct 11, 2006 | 05:00 PM
MrB18crx
I cant see any wires up there were are they exatly.Its a 90 si if that helps.
wb_map3
Old Oct 11, 2006 | 05:01 PM
MrB18crx
How do you hook up a starter button
wb_map3
Old Oct 11, 2006 | 05:08 PM
hatchback1994
I had the exact same yr rex except mine was a dx, trust me the wires are there, all honda's have the clutch safety switch, I jumped mine on my rex before and I recently did it on my 94 civic...if u have the cash just go to the parts store and buy a new switch then u will know exactly what it looks like
Old Oct 11, 2006 | 05:39 PM
MrB18crx
I believe you but I just want to know exactly were to look I couldnt see it. I also cant find anything on it. Do you know of any write ups on this.
wb_map3
Old Oct 11, 2006 | 05:50 PM
hatchback1994
here's a write up Honda-Tech.com: EDU: Bypassing the clutch
Old Oct 11, 2006 | 06:07 PM
MrB18crx
Dude thanks so much man. I even looked on honda tech. Thats cool I hope thats what it is. rep givin
wb_map3
Old Oct 11, 2006 | 06:11 PM
hatchback1994
no problem...remember u can start your car in gear so b careful
