97 civic keyless - headunit
Alright guys, I'm sure you've heard this problem before. I bought my car with an aftermarket HU already installed, so neither the keyless entry nor the dome light sensor work. I read that I have to get a stock radio and hide it behind the dash, so I went to a pull-it yard and bought a 98 Civic stock radio. The bad thing is, it turns out there are 2 extra pins on the green (p18?) connector for the keyless entry. Do you guys happen to have a pinout for the radio and the connector so I can solder the wires manually? I already know which pins to splice off the main audio/power connector, I just need to know which wires go to what on the smaller green connector. If necessary, I can post pictures. Thanks in advance for your help.
So no one has had problems with their keyless in their EK's? Basically, all I need to know is either the pinout of the security connector on the back of the 98 radio and the 97 connector, or I need to know where to get an adapter.
