clutch releasing to high??
Old Sep 21, 2006 | 03:49 PM
Willis's Avatar
Default clutch releasing to high??
i have been having this problem every since i put my 6 puck clutch with heavy duty pp in. It seems as if the clutch is releasing at the very top. I've tried bleeding the clutch to see if air comes out, but i only get fluid. i also moved the pedal itself down lower to see if that would help, but it didnt. Any one have any ideas?? The clutch maybe has 3,500 miles on it. Thanks
Old Sep 22, 2006 | 03:37 PM
Willis's Avatar
ttt anyone???
Old Sep 22, 2006 | 05:32 PM
si0385.'s Avatar
jdmasfuk
same thing happened when i put my 4 puck in with a hd pressure plate its normal
you will get used to it after a lil bit
Old Sep 24, 2006 | 09:07 PM
For some cars,
If the clutch is hydraulic, I would make/install an adjustable threaded rod
out at the bell housing, so I can control the release point.-Bob
