whats the best oil for integra 95gsr 86xxxmiles
I always use Mobil 1 sythetic. its $30-$40 if you change it your self with a mobil 1 filter. it comes in vipers and cts-v and most benzs and like all the super cars from the factory.
She may not look like much but she's got it where it counts....I've made a few special modifications myself
well it has 86,000 miles on it... does it smoke, burn oil, or have any major oil leaks?
ususally when a car gets to its middle to old age you wouldnt want to run synthetic in it... if your gaskets are old and worn out, synthetic is said to make them start leaking or leak worse if they are already leaking... the best thing for a car like yours which is kinda in the middle ages for a honda would be to use 10w30- that is if you dont smoke, burn oil, or leak oil... if you do smoke or something the 10w30 would be too thin... therefor you would need to run 10w40 because its a thicker base oil which is perfect for a middle aged motor. 20w50 would be too thick unless you burn a whole lot or leak a whole lot...
go with 10w40
go with 10w40
if you have used synthetic, stay synthetic. if you have used conventional, stay conventional. i ran castrol GTX cheapy 5w-30 in my Y7 for years, it had 130k+ miles. id say use that.
factory spec for your car is 5x-30 i believe.
go with 10w40
go with 10w40
+1
Royal purple and k&n filter !!!
EATING FORDS-SHITTING CHEVY'S
MOBIL 1 LUBE
11210 Causeway Blvd. Brandon 33511
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
At the Mobil 1 Lube in brandon we service all your automotive needs.Specialize in Honda/Acura. B series swaps etc. No job to big or small.We are located right in front of Walmart. Ask for Nate.
MOBIL 1 LUBE
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
what he said....or if you dont want a K&n filter you can always go for a hamp
NOW Im SPRAYING
Dont Be A PUSSY Spray That SHIT!
www.ogrbreaks.com" target="_blank" rel="noopener noreferrer nofollow external">www.ogrbreaks.com
www.unitedbreaks.fm" target="_blank" rel="noopener noreferrer nofollow external">http://<span style="color:Blue">www....eaks.fm</span>
HUNGRY? DON'T GO AND HUNT FOR DEER JUST FUCKING HIT THEM WITH YOUR RIDE!
NOW Im SPRAYING
I'll trade ya for some castrol
