crx dumping fuel in cylinder
Old Sep 18, 2006 | 09:29 AM
squid00's Avatar
teh clit wiggler
Default crx dumping fuel in cylinder
crx with b16a1 obd0 dumping fuel at cylinder 2 and 3. basically injectors 2 and 3 stay open.
i have tried and replacing the engine wiring harness twice already and still no luck. i need help please, what do i need to start looking at.
Old Sep 18, 2006 | 09:40 AM
YARO's Avatar
Smith & Wesson Protected.
have you checked injectors??try switching them out?
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Sep 18, 2006 | 11:05 AM
squid00's Avatar
teh clit wiggler
injectors were all stock. maybe i should change em to some known injector that ran well.
thanks for the input. ill go check that and get back here again.
Old Sep 18, 2006 | 11:09 AM
integraman89's Avatar
lost u already???
are you sure they are getting enough spark?
Old Sep 18, 2006 | 11:11 AM
mtber's Avatar
The issue could be anything from wiring to a bad ecu/injectors etc.
Is the engine computer reporting any Malfunction Idications ?
Old Sep 18, 2006 | 02:01 PM
BG-33P_Hatch's Avatar
Back in the Game
+1 is it throwing any codes?
R.I.P. Kevin Gonzales Aka Slo_Si
You will be missed by many.
R.I.P. Robert Kolp Aka 00ek
You will be missed brother
R.I.P Jake D Aka Cold_Beer
you will be missed brother
Old Sep 18, 2006 | 04:41 PM
squid00's Avatar
teh clit wiggler
this problem goes way back from 2005. i had to literally play around with the wires from the injector to the ecu. basically i wired the yellow, blue and brown injector wires straight from the ECU (bypassing the harness that goes to the resistor box, and the red wire was just wired the same way stock.
it took two days to finally get the firing order right. but then code 14 kept us from driving the car right.
few months passed and i finally took a chance of swapping the whole engine harness with a fresh new one from a crx si (bought it from sillywhips here) and put it in. well guess what,. i was back to square one. the car wont start and code 15 comes on....... plus cylinder 2 and 3 is getting filled up with gas.
i am not so sure what to do anymore. been playing around with this project car for more than a year. somehow, 2 of my injectors are getting "signal" to stay open the whole time, thus drowning the engine.
Can someone please help me with this. I am running out of options and most of all, hope.
ill post my previous threads here in a sec....
Old Sep 18, 2006 | 04:46 PM
squid00's Avatar
teh clit wiggler
https://www.tamparacing.com/forums/h...pping-gas.html
https://www.tamparacing.com/forums/h...need-help.html
here it is..... after 1 year, im still no where near getting it done.
Old Sep 18, 2006 | 04:49 PM
squid00's Avatar
teh clit wiggler
i have tried 3 ecus...... two regular/stock pm6 ecu and a pm6 ecu chipped by Zdyne.
Old Sep 18, 2006 | 04:51 PM
squid00's Avatar
teh clit wiggler
we had it running and idling good so that means it was getting spark. but now after swapping another fresh engine harness, it wont even start anymore and the engine floods.
