Info About Brakes
i need to know if at all possiable i am able to bolt up bigger brakes on my 01 teg its a ls just wondering if gsrs calpers are bigger also i know itr calpers are bigger but will they bolt up to a ls mount 01 lmk please
+1 ......Good find man
R.I.P. Kevin Gonzales Aka Slo_Si
You will be missed by many.
R.I.P. Robert Kolp Aka 00ek
You will be missed brother
R.I.P Jake D Aka Cold_Beer
you will be missed brother
im looking to up grade i want to see what causes the pistons in the calpers to stay out while not appling the brakes ??? i jack up the car unbolted both calpers right left strated car pressed brakes pistons come out but do not retracked back into calpers fully. so put right and left calpers back on the car repeted the same test and after pressing the brakes one or the other rotors would not spin but not both at the same time after being off the brakes what is this the master cyclender going a vacume leak or bad brake lines
What wheels are you running ?
There are aftermarket big brake kits on the market...
