what type is this tranny
Old Sep 12, 2006 | 04:07 PM
rsgredrum's Avatar
boostaholic
Talking what type is this tranny
i got a s80 tranny and my clutch kit dont fit.the clutch i bought it for a gsr cuz thats the motor that came in the car and it dont fit does any one know what tranny this came out of.
Old Sep 12, 2006 | 04:39 PM
Pyroproblem's Avatar
Porsche Tech/Honda Tech
I believe all the b series pressure plates are interchangeable,the clutch disc is different. Cable trannies i think have different input shaft splines than hydro ones so discs are not the same.
If you ordered a gsr clutch and it wont fit, you may be using a ls cable tranny. Cable B16 trannmissions also...
Old Sep 12, 2006 | 05:03 PM
rsgredrum's Avatar
boostaholic
Talking S80 Tranny
[quote=Pyroproblem;3484337]I believe all the b series pressure plates are interchangeable,the clutch disc is different. Cable trannies i think have different input shaft splines than hydro ones so discs are not the same.
If you ordered a gsr clutch and it wont fit, you may be using a ls cable tranny. Cable B16 trannmissions also...[/quote
my tranny is a hydro tranny but the clutch could be for a cable. the disk haves a shaft hole that is small my s80 is big shaft...
Old Sep 12, 2006 | 05:09 PM
97HATCHY's Avatar
I Think The S80 Is A Ls Tranny If I Remember Correctly
Old Sep 12, 2006 | 05:19 PM
99B16Si's Avatar
S80 = hydrolic LS tranny
Old Sep 12, 2006 | 05:48 PM
Cold_Beer's Avatar
Rockin' 4 more Cylinders
s80 can be a couple different trannies.....
Ls. itr, ctr etc. Does it have a vin plate on it?
The only clutch's that have diff spline, is small spline 90-91 and i think 00si.
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old Sep 12, 2006 | 05:50 PM
lzylst's Avatar
s80 stamped case could be LS, GSR or ITR.
Sounds like you have a -91 clutch disc if your disc has a smaller whole than th etranny input shaft. If it came as a kit the throw-out bearing will be different also.
Jake beat me to it! The sc4 's a(99-00 b16) are big spline also.
Old Sep 12, 2006 | 06:59 PM
95w_bTEG's Avatar
!!PORTUGAL!!
all B-series hydrolic clutches are interchangeable, some thing with cable, B-series.
hydrolic have a bigger spline, and difference in the teeth
Old Sep 12, 2006 | 07:13 PM
lzylst's Avatar
No, they are not all the same. Don't give misleading information.
Old Sep 12, 2006 | 07:20 PM
95w_bTEG's Avatar
!!PORTUGAL!!
fkin vicodin
