92 integra wont start
Old Sep 12, 2006 | 10:52 AM
integraman89's Avatar
lost u already???
Originally Posted by kelvinLS
i have no spark ..........and when i turn the key to on position and wait for the check engine light to turn off it doesnt....so did my ecu give up on me?
did you check for spark using the method i stated above? If not, try that first and that will eliminate the ecu possiblity... by checking the spark in ur wires that will narrow down the problem a bit, if you are not getting any spark at all with that method, check ur ignition relay, check ur dizzy car and ur dizzy rotor and make sure they are not corroded or wore out, if the relay is good and your cap and rotor is good... your internal coil may be going bad or may be bad already. do the spark test first, if no spark check cap and rotor and ignition relay, if all good... check your internal coil.
Old Sep 12, 2006 | 11:14 AM
kelvinLS's Avatar
klvnls
ok i did all that and still nothing...........i put everything new and nothing......
Old Sep 12, 2006 | 04:19 PM
integrex's Avatar
dood...its the ignition relay...are you sure you replaced the right one?
Old Sep 12, 2006 | 05:05 PM
kelvinLS's Avatar
klvnls
where is the ignition relay located??????
Old Sep 12, 2006 | 06:56 PM
integrex's Avatar
get on your back on the drivers side and look up under the dash its the biggest one there
Old Sep 12, 2006 | 07:01 PM
CivicLSGod's Avatar
and i was about to trade ummm let me know kev iight...
Old Sep 12, 2006 | 10:38 PM
  #17 (permalink)
lost u already???
sorry man but your wrong... the ignition relay is under the hood in the fuse/relay box... you will have an ignition fuse which is like a big green 30amp fuse which is screwed in with 2 screws and you will have a few black squares that plug in those are relays, they have anywhere from 2 to 4 prongs on the other end after you unplug one. if it doesnt say which is it on the black lid of the fuse/relay box, check your owners manual to figure out which one is the correct one. the fuse box which is under the dash is only small amp fuses like anywhere from 5 to 25amp. those would just be for the minor electronics... such as radio, headlights, brakelights, ac ...etc. refer to your owners manual or even the haines manual to find the correct fuse/relay. - Jason
Old Sep 13, 2006 | 06:14 AM
  #18 (permalink)
kelvinLS's Avatar
klvnls
i checked those already but im goin to double check
Old Sep 14, 2006 | 11:51 AM
  #19 (permalink)
kelvinLS's Avatar
klvnls
bought The Ecu Today And The Car Turned On And Is Running Perfect...............
thanks To Everyone That Helped!!!
Old Sep 15, 2006 | 09:02 AM
  #20 (permalink)
lost u already???
good job... good luck and have fun
