high Compression Questions
Old Sep 11, 2006 | 05:28 PM
aznkhmerracernza's Avatar
Default high Compression Questions
I just ordered a set of CTR Pistons for my LS/VTEC. I heard i will encounter Gas problems such as not being able to use Pump Gas. My compression Came out to a 12.4:1 CR. One of my more experience tech at work told me if I did some headwork that i wouldn't have to worry about using Pump fuel. Basically right now This is what my set up is.
Head work-
B16 Head, Skunk2 Valvetrain,Skunk2 STD Size Valves, KMS Silicon Bronze Valve Guides, AEBS IM, Hondata IM gasket, 70MM Holley TB, AEM Fuel Rail, RC 310 Injectors, B&M FPR, Port and Polish, 3 Angle Valve job, Buddy Club Spec 4's cams and camgears, OEM 3-Layer Head Gasket, and TODA Timing BELT.
Block-
B18A1, Shotpeened PR4 Rods, CTR 81mm Pistons, ACL Race Bearings and Thrust Washers, P30 OIL and Water Pump, ARP MAIN, ROD, AND Head Bolts.
Am I safe to use 93 Octane or will I encounter Pings and pre Det.
USS MAINE BLUE CREW, BANGOR WASHINGTON!!
www.myspace.com/maknpanna
Old Sep 11, 2006 | 06:34 PM
mtber's Avatar
Head work-
Block-
93 oct will be ok once the vehicle is tuned properly.
I have tuned several 12.0-12.5:1 ctr piston setups.
They are ping happy, especially with hot intake air temperatures.
Unfortunently they have to be de-tuned to prevent pre-ignition on 93 oct with florida's hot IATs.
I would recommend double stacking a oem headgasket to lower the c/r just so you have a little more room to play with.
Let me know if you have any other questions. I will be more then happy to answer them.
Old Sep 11, 2006 | 07:15 PM
chi town brat's Avatar
! Ne shab'rud'ni !
no problems with my 12.6:1 compression ratio on 93 as of yet
but due to autox'ing in the Florida heat, i've opted to head over to Sunoco on Dale Mabry by Waters and go for the 100 octane
Amazing how it has stayed at $5.99 per gallon all summer long. I only drive the car for events so I don't mind filling it up.
Old Sep 11, 2006 | 07:20 PM
Cold_Beer's Avatar
Rockin' 4 more Cylinders
How much timing is pulled from the motor, on pump gas?
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old Sep 11, 2006 | 08:56 PM
mtber's Avatar
12.6:1 compression ratio on what ecu program ?
What is your distributor's base ignition timing at ?
Old Sep 12, 2006 | 08:10 AM
! Ne shab'rud'ni !
d16y8 on 93 octane
12 degrees of timing at dizzy
cam gear is negative by . can't remember
38 for the fpr
stock obd0 ecu program
engine runs great. no detonation. no problems.
270 static compression across the board.
Old Sep 12, 2006 | 08:30 AM
mtber's Avatar
d16y8 on 93 octane
38 for the fpr
Stock obd0 ecu program from what ecu ?
If lets say you are running a standard p28 style map with a base timing of 12 deg btdc. Your total timing values at full load are probably around 24.50 deg btdc. This would explain why you are not having any kind of pre-ignition
Old Sep 12, 2006 | 10:53 AM
Cold_Beer's Avatar
word
_Jake D
Old Sep 12, 2006 | 11:33 AM
KJ's Avatar
KJ
bored at work
I'd recommend dropping the comp ratio down to 11-11.5:1. No sense running higher compression and then having to de-tune your car to be able to drive it. I've built street NA motors in comp ratios from 11:1 to 13:1 and from experience I don't recommend higher than 11.5:1 anymore.
Old Sep 12, 2006 | 11:38 AM
rangcrx's Avatar
engine building &best
me to i did this with my own lsvtec and it sounds like shit and with stock cams even worse send them back and get some usdm intera typeR pistons or find someone to trade you there b16 pistons
i love AUTOZONE
