Car is finally running.....now back to old problem
Old Sep 11, 2006 | 12:26 PM
phidelt583's Avatar
Angry Car is finally running.....now back to old problem
Ok guys I finally got around to fixing my car sunday. Now that it is running agian I am gonna try to tackle the old problem it is still having.
I'm sure you all have read my posts before but here is my problem again. I have a 99 EK that had an OBD1 Ls in it. The Ls blew so I swapped in a Jdm b16a Obd-O. When the swap was done the car ran good, pulled hard, vtak kicked in.....I just couldnt' give it FULL throttle.
Anytime I give it full throttle it bogs down almost as if it cuts off the fuel. As soon as I take my foot off the gas the car starts to run fine again.
Here is what I have done:
I replaced the throttle body with the ls one...... problem not fixed
I changed the vss.......problem not fixed
I replaced the fuel pump.....pump was bad, but this problem not fixed
I checked all grounds and wires.......nothing loose...problem not fixed
PLEASE HELP ME
DURANGO FOR SALE OR TRADE
Old Sep 11, 2006 | 12:32 PM
drkspid4's Avatar
what ecu are you running? the b16a is a DOHC motor if your running a unchipped SOHC ECU thats probably why its cuttin out because its programmed for a single cam motor which means less fuel and more air.
Old Sep 11, 2006 | 12:41 PM
phidelt583's Avatar
i'm using a p30
Old Sep 11, 2006 | 02:38 PM
60-1EK's Avatar
Engineer at the source
Any CELs? What distributor and injectors are you running?
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Sep 11, 2006 | 02:52 PM
phidelt583's Avatar
No CELs.....I am using the injectors off of the LS....they are obd1 so does that make a diff.....and I have no clue about the dizzy....how do I check and what should I use?
Old Sep 11, 2006 | 03:24 PM
mtber's Avatar
Check one of the injectors with an ohm meter to double check your injectors are 12-13 ohms to ensure you are running the proper SATURATED injectors.
I am guessing you are running an obd1 or obd2 distrubutor, if you are running the obd0 dizzy this is your problem.
Old Sep 11, 2006 | 03:33 PM
phidelt583's Avatar
How do i know what dizzy I'm using? I think I am actually using the obdO dizzy that came on the motor. If this is the problem can I just swap out the dizzy that is on my old ls?
Old Sep 11, 2006 | 05:38 PM
phidelt583's Avatar
Can anyone help me with these dizzy questions?
Old Sep 11, 2006 | 06:24 PM
mtber's Avatar
You must use an obd1 or obd2 dizzy with the obd1/obd2 ecu.
Old Sep 11, 2006 | 11:57 PM
djlobes's Avatar
Im sofa king we todd did.
from what i can tell by doing a little research an obd0 dizzy has 2 round plugs on it where as and obd1 dizzy has 2 square plugs. obd2 dizzy should only have one plug. now, i think your still using the obd1 wiring harness from the ls so u should be using an obd1 dizzy unless u see a conversion harness or its hardwired in. of course i could be wrong though.
oh, and did u borrow my porn?
