ecu change with manual swap?
Old Sep 10, 2006 | 04:35 PM
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
Default ecu change with manual swap?
If I was to change my auto to a manual from say a gsr or a civic si trans wouldn't I need the ecu from the manual ls or manual gsr?also would a civic si trans bolt up right to an ls (b18b1) block?
Old Sep 10, 2006 | 05:55 PM
BG-33P_Hatch's Avatar
Back in the Game
Yes a 99-00 Si Transmission will work on a B18b Block.....No you would not have to change Ecu's for it to work but I would recommend that you get a Manual Ecu or get the one you have Chipped.....Phearable.net can help you out
Old Sep 10, 2006 | 06:20 PM
K20A2's Avatar
Alright man thanks a lot for the info.why would u reccomend getting it chipped tho?and how much would a 99-00 si trans run me moneywise?
Old Sep 10, 2006 | 06:44 PM
Back in the Game
Getting your auto Ecu chipped to manual is what I am referring to. A good 99-00 Si transmission will run you anywhere from 500-700.
Old Sep 10, 2006 | 06:52 PM
K20A2's Avatar
Alright I might end up doing that after I get the swap.can you recomend any good places that can do the swap?I've looked in the shop directory and I've got a couple places I'm going to call to get prices but they're kinda far from where I live.thanks for the info btw
Old Sep 10, 2006 | 07:05 PM
mtber's Avatar
+1 you can have your auto p75 chipped to manual specs.
Old Sep 10, 2006 | 07:17 PM
K20A2's Avatar
Alright thanks mtber,btw what's the diff between auto and manual specs?
Old Sep 10, 2006 | 07:25 PM
mtber's Avatar
An auto ecu will throw a code 19 on a manual vehicle.
It will also idle awkward & etc..
Old Sep 10, 2006 | 07:26 PM
Back in the Game
Old Sep 10, 2006 | 07:32 PM
K20A2's Avatar
Alright thanks,do you know of any good places to get it done that are closer than st pete or the 727 area?im in 813 and those are kinda too far.
