b16 ac guide plz help
I have a eg wit a b16 and i got the bracked and the whole ac set up i just need to install it. Does anyone know of a guide for doing this. plz pm me or post here
make sure u put oil on all of the o-rings when putting them together.take ur time cause those lines are not the strongest.make sure u have everything hooked up correctly before u try to get it to work.and the compressor wont click on until u start to put the oil and the r-134 thats all i think
9/13/06-R.I.P. Kevin aka Slo Si, you will be missed
06-07-2006 01:47 AMSlo_Siwhen the spinnin ends, the bullshit ends...
xbox 360 gamer tag slohatch93
Jap Tuned!!
Jap Tuned!!
If you compressor does not kick over due to no pressure in the lines, make sure you jump the pressure switch. you will need to do this to get it to pull any refrigerant into the system. Good luck. -Ben
