Adjusting Rear Disc
Adjusting Rear Disc
I recently Hooked up my EJ8 with some New GSR brakes. The Front Grabs real hard, but i realize the load of my braking is Directed towards the front. I keep having to drive cautiously in the Rain because When i brake even half hard it seems to Lock. I tried pulling the e-brake and testing it out. It has no effect towards the Rear. Can it be the Calipers or is there a way i can adjust them? Feedback would be greatly appreciated and I hate not driving my car because it's to dangerous to be out on the road. Having my LS/VTEC Swap already in It sucks Not being able to go out to the track with Such a Serious Hazard on the road.
Nope I didn't get a Proportioning Valve. I heard you didn't need one. My e-brake does go up all the way.
You DEFINITELY DO need a proportioning valve, and I would reccomend tightening the ebrake cable (and make sure you have the right one... )
When I did the rear disc conversion on my car from a 2000 civic si, i used the si ebrake cables, 40/40 proportioning valve from an EG Si hatch back, Type R brake booster and master cylinder... Brakes work great and stop the car with the quickness from any speed... Just be sure to invest in some GOOD pads and rotors, and I also reccomend stainless brake lines... Brakes are the most important part of the car IMO... Whats the point of goin fast if you cant slow it back down???
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Thanks for the Help. Money isn't an option for me I just Want My car to be safe. I will definetly Check them Out tommorow. Rep For you.
How much was the Brake Booster and Master Cylinder?
Picked it up used for $100... Just gotta look around HondaTech and maybe even eBay
