***Need Help with 94'Integra Steering Rack Installation***
Old Aug 30, 2006 | 03:51 PM
UpInYa's Avatar
Marijuana my anti-drug
Default ***Need Help with 94'Integra Steering Rack Installation***
TR please help me with instructions or a tip or anything on my steering rack...need to fix asap!!! It's on a 94'teg
Old Sep 2, 2006 | 11:06 PM
General principles (without seeing your specific car)......
Jack up/remove wheels. Jack stand the front end.
Undo tie rod ends. 2 nuts.
Undo 2 U-shaped clamps holding rack...under car. 4 bolts.
Inside car; lift floor mat around steering column,
and undo universal joint. 2 bolts.........maybe a few
fasteners to get to those 2 bolts.
If power steering: undo 4 hose fittings/nuts under car. Catch oil in something.
Turn wheels full to passenger side, and slide rack out toward passenger
side until drivers side drops down; then slide rack out toward driver's side.
When installing a rack, try to get the steering wheel straight when the universal joint goes back on, and top up the power steering fluid, afterward.
A secret: small cars don't need power steering, and over a year ago, I totally removed mine, cut off and capped the lines 1" from the rack....and removed all other components related to power steering.-Bob
Old Sep 3, 2006 | 03:55 PM
UpInYa's Avatar
thanks man ..big help
