what head do i have???
Old Aug 29, 2006 | 02:00 PM
tunabanana79's Avatar
< 12 parsecs
Default what head do i have???
when i bought my car i was told it had a mini me swap, i just want to know what head i have, where can i look to figure this out? and also where can i look to see what block i have? i dont think its the original from the car, i was told it only has 60000miles on it. i just want to figure out exactally what my set up is. thanks in advance.
DAMIAN
She may not look like much but she's got it where it counts....I've made a few special modifications myself
Old Aug 29, 2006 | 02:20 PM
88RedRex's Avatar
Protected Taurus .45/.410
mini me swap is a single cam vtech what number does it say on the block it should be like d16y8 or d16y7 but the y7 is non vtec, it should say the numbers rite under the head where the tranny and block meets
Old Aug 29, 2006 | 02:34 PM
< 12 parsecs
thanks, ive got a D15B1 block now i just need to know what head i have where can this be found???
DAMIAN
Old Aug 30, 2006 | 05:17 AM
skilly's Avatar
POSH
well u can c if its v-tec or not by finding the lil solenoid under the breather on the valve cover if thare is one then its v-tec which would mean its a z6 head or y8 (i think the z6 and y8 are the only v-tec d16 out thare not sure tho)
Old Aug 30, 2006 | 05:19 AM
skilly's Avatar
POSH
o and look and c what kind of ecu u have . a p28 is a v-tec ecu just to let i know
Old Aug 30, 2006 | 07:04 AM
< 12 parsecs
yes i have the solenoid, i know it is vtec for sure, there is a little light next to my tach that comes on when the vtec kicks in and i hear/feel the difference as soon as it kicks in, i would just like to know which vtec head i actually have. thanks
DAMIAN
Old Aug 30, 2006 | 12:44 PM
EconoBox's Avatar
Four Door Mafia
Mini-me swap is a d16 head (one w/ VTEC) onto a D15 block(USDM non-VTEC). And if you want to know whether or not you have VTEC on a single cam just look at where the plug wires are. No VTEC the plugs are on the back of the valve cover towards the firewall, with VTEC they are on the front. Hope this helps.
There is no way to tell exactly which head you have that I know of(without removing it). Its just some form of a D16 VTEC head. If you want to know for sure ask the person you bought the car from.
ECU Chipping, Tuning, Custom Wiring, and any other automotive needs. PM me for a quote.
Hmotors/Hondata/Hasport/JHPusa/PasswordJDM
stores. Most parts in stock or 1 day away!
Old Aug 30, 2006 | 03:06 PM
rangcrx's Avatar
engine building &best
DAMmmmmN
i love AUTOZONE
Old Aug 30, 2006 | 03:29 PM
YARO's Avatar
Smith & Wesson Protected.
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Aug 30, 2006 | 05:23 PM
< 12 parsecs
i know that the indicator light doesnt mean that i have vtec, i know i have vtec, i just wanted to know which vtec head i had, i want questioning if i had vtec or not, i have the solenoid and i have a vtec head, i just didnt know which one. im not a complete moron, i just dont know an extensive amount about these cars. thank you EconoBox for answering my question, and thanks every one else that helped.
DAMIAN
