help!!! no fuel pump,batt. light,and solid cel
Old Aug 15, 2006 | 07:19 PM
WagonMaster's Avatar
vtec yo!
Default help!!! no fuel pump,batt. light,and solid cel
alright here's the rundown
1988 civic sedan
D16Z6
engine harness tucked "not the first ime ive done this either"
OBD-1 conversion
car ran around the block once and when i tried to go again i only made it 1/2 way and it died
ive checked my ECU its good
and ive checked my main relay its good
ive checked my wiring and voltage at my fuse block all good
and still no battery light
no fuel pump
and a solid check engine light
im completely out of ideas so if this has happened to anybody else PLEASE post the problem and your solution
ive been by this problem
Old Aug 15, 2006 | 07:26 PM
Jap's Avatar
Jap
VTEC Out
Originally Posted by WagonMaster
semi wire tucked
Problem found
Hondata saves lives
Old Aug 15, 2006 | 07:35 PM
vtec yo!
i said i checked my harness ,and this isnt the first time ive done this, and i said semi cause the pass side light harness isnt done yet so the engine harness is copletely tucked. let me know if you have any USEFULL information
Old Aug 15, 2006 | 07:38 PM
Jap's Avatar
Jap
VTEC Out
Ok well When current is passed through the wire if it tuck was done incorrectly or crappy then it may short causing a solid CEL or any of the above things ..
Replace harness with a Non-Modified version and I would be willing to bet the car will work correctly
Hondata saves lives
Old Aug 15, 2006 | 07:42 PM
vtec yo!
but what could cause all of the above to happen at the same time so i can check that cause i know my wiring is good it wasnt cut just unwrapped and rerouted
Old Aug 15, 2006 | 07:43 PM
Jap's Avatar
Jap
VTEC Out
Ground on thermostat housing ?
Fuel pump prime ?
Hondata saves lives
Old Aug 15, 2006 | 07:45 PM
vtec yo!
its on
and how would priming the fuel pump (if im incorect about what you ment lmk) change my batt light a solid cel
it ran fine for about an hour?
Old Aug 15, 2006 | 07:48 PM
Jap's Avatar
Jap
VTEC Out
No does the fuel pump prime when you turn the key to the ON position ..
This usually designates a bad ground situation ..
Solid CEL means ECU and hte Batt light to me means blown fuse form a high aperage draw or a short in the wiring .. Hence why i said the tuck mroe than likely being your problem ..
Hondata saves lives
Old Aug 16, 2006 | 01:17 PM
vtec yo!
fuel pump doesnt turn on and there are no blown fuses
Old Aug 16, 2006 | 03:32 PM
TSX24L's Avatar
is the chip in the ecu in correctly? or the jumper?
