odb1 or odb2 convertion
Old Aug 15, 2006 | 09:25 AM
nab16crx's Avatar
Default odb1 or odb2 convertion
i got a 97 hatchback i want to do a gsr turbo what would be less of a headache buying an odb1 motor and changing it to a two or buy a two? i know they dont make tunes for the two. what will i have to do to change a one to a two?
Old Aug 15, 2006 | 10:41 AM
96ek's Avatar
buy a obd2 motor and convert your 97 hatch to obd1.g/l
Old Aug 15, 2006 | 10:59 AM
mtber's Avatar
I would recommend buying an obd2 swap so you don't have to hackup an obd2 harness to run obd1 components.
Buy a obd2 gsr swap.
Buy an aftermarket intake manifold such as the Eddlebrock for a turbo app.
Buy the proper rear L bracket needed along with the proper top drivers side mount bracket & a/c bracket.
Buy the proper throttle cable.
Buy a obd2 to obd1 conversion harness and chipped obd1 ecu.
Convert your IACV wiring from 3 wire to 2 wire (phearable.net)
Good Luck.
Old Aug 15, 2006 | 12:35 PM
BG-33P_Hatch's Avatar
Back in the Game
Good Luck.
Thats about it on this subject...Good info John
R.I.P. Kevin Gonzales Aka Slo_Si
You will be missed by many.
R.I.P. Robert Kolp Aka 00ek
You will be missed brother
R.I.P Jake D Aka Cold_Beer
you will be missed brother
