taking off the crank pully?
how can i pull off the crank pully? the motor is in the car. when i use a breaker bar it turns the motor.am i doing sometihng wrong?
phearable.net
R.I.P DJSTANG. YOU WILL NOT BE FORGOTTEN!!!!
phearable.net
You will need a Compressor and an Impact, Preferably one with a good amont of Psi behind it. Hit it a few times....If it doesnt come loose Hit it a few times the opposite way then try the other way again. Just my .02
R.I.P. Kevin Gonzales Aka Slo_Si
You will be missed by many.
R.I.P. Robert Kolp Aka 00ek
You will be missed brother
R.I.P Jake D Aka Cold_Beer
you will be missed brother
its a pain to get off, easiest way if you have access to a GOOD impact wrench, it will usually take it off....i usually take a good size flathead scredriver and wedge the flywheel and use a breaker bar.....but im sure people will have something to say about that....there are many ways...good luck
ok, i have a compressor. but i guess the impact i have inst good enough. i will give it a try with a better one and see what happends.
phearable.net
phearable.net
go buy the Crank Tool. Snap Onsells them Cheap or I think Sears can order them. I used to have one. You ever notice the Hexagonal Shape of the ID of the pulley there is a Tool that Fits that with about a 24" bar that you hold it with and remove the bolt without spinning the engine. Constant Shock to the end of the crank can cause cracks.
eBay: NEW Honda & Acura Crankshaft Pulley Holder Tool 1990 - (item 160017348021 end time Aug-16-06 03:35:54 PDT)
Hows it coming man??? Let us know
taking the crank pulley off is a bitch.. hahaha yea take a pri-bar and shove it to the flywheel.. then have a 2FT. braker bar and an extention if you can... and have a FAT FREIND..(over 200pounds).. jump on it.. thats how i got my crank pulley bolt off.. hahha just letting you know..
